christinerodgers
PC Specification: Windows 10 Geforece gtx 750 Ti Intel I5
Question about mirillis action
Mon Jun 17, 2024 4:28 am
Hello all,
I recently learned about this software and i try it.
It's working Great. I got to record some gameplay of borderlands with HDR on. And it doesn't look washed out.
But my question is. There is no info on the settings.
I been wanting to increased the video quality. I don't see the option. There is just a preset to ultra. But i would like yo increase the bit rate.
Anybody here can help me with that. Thanks
Re: Question about mirillis action
Thu Jun 20, 2024 5:56 am
Hello.
Go to Settings -> Video, select option "Force bitrate" and set bitrate you up to 100 Mbps.
Loaksi
PC Specification: CPU model
Thu Aug 29, 2024 4:11 am
It has been my intention to enhance the video's quality. The choice isn't visible to me. Just a single setting will take it to ultra.
haulwhirlwind
Mon Sep 30, 2024 7:17 am
You should go to settings and choose to customize the quality level you want.
Return to “General Topics”
