Lukamundo
PC Specification: RTX 4070 TI, Windows 11, AMD Ryzen 5900X
System Freezes when switching to second screen display recording
Wed Jun 19, 2024 4:22 pm
Just like it says, when I try to use display screen as the recording area, the moment I pick the second monitor from the drop-down, it completely freezes my entire PC. My mouse can still move around, but everything else just freezes. It won't come out of it no matter how long I wait. Even hitting alt+F4 or any other hotkey doesn't do anything. ctl+alt+del doesn't even work.
Can someone help me. This program use to be great, but lately it is not working well at all.
Re: System Freezes when switching to second screen display recording
Thu Jun 20, 2024 5:55 am
please provide us your PC DxDiag report. It will help us investigate your problem.
Click on, "Start Button".
Click on, "Run".
Lukamundo
Sat Jun 22, 2024 1:55 am
Here is my dxdiag info. I had to zip it as you don't allow standard txt files.
DxDiag.zip
(18.58 KiB) Downloaded 3237 times
Tue Jun 25, 2024 5:54 am
So when you switch from your 3440x1440 monitor to 1080p monitor the problem occurs?
It is happening without recording, right?
Does the same happen if you use F8 hotkey to switch between displays?
Users browsing this forum: No registered users and 48 guests
