highlightscaly
PC Specification: Windows 11
can't upload 2 audio tracks
Wed Sep 18, 2024 1:40 am
why can't i turn on both audio tracks when uploading videos to youtube?
limemules
PC Specification: Windows 10
Re: can't upload 2 audio tracks
Wed Dec 25, 2024 6:53 am
YouTube only supports one active audio track per video. If you upload a video with multiple audio tracks, YouTube will typically use the default track. To include multiple audio options, you can:
Merge Tracks: Combine the audio tracks into one using video editing software.
Upload in Multiple Languages: Use YouTube Studio's "Captions" or "Audio" features to add alternate audio tracks for language purposes (if your account supports it).
plausiblefell
PC Specification: CPU
Wed Dec 25, 2024 7:03 am
YouTube only supports one audio track per video. Combine tracks in editing, upload separate versions, or use subtitles for multiple language options.
cloakedcocktail
PC Specification: Window 10
Fri Apr 25, 2025 3:57 am
You can't turn on both audio tracks when uploading to YouTube because YouTube only supports a single audio track per video. YouTube's video player is designed for the average viewer, so it doesn't include features like selecting audio tracks (like on a DVD or Blu-ray). When you upload a video, YouTube re-encodes it to multiple formats for streaming. It picks one audio track to keep and discards any extras.
bukarim
Tue Jun 10, 2025 2:11 am
Even though you can upload videos with multiple audio tracks, YouTube only allows one audio track to be active during playback. This is by design because YouTube’s player is not meant to mix or blend multiple audio tracks simultaneously.
dolecomplex
Wed Jun 18, 2025 7:59 am
You cannot play both audio tracks (e.g. background music + voice) when uploading a video to YouTube unless they are pre-mixed into the same audio file in the video. When you upload a video, YouTube only plays one main audio track. It does not have the ability to play two separate audio tracks side by side like editing software does.
Return to “General Topics”
