PamelaCShope
PC Specification: Intel Core i7-9700K
I can't export video from C drive to D?
Tue Dec 17, 2024 2:12 am
Hi all, I can't export videos from C drive to D drive? I tried everything to transfer videos to D drive but it shows a red error. I tried everything but it doesn't export. I need to fix it now.
frequentcrushed
PC Specification: CPU model
Re: I can't export video from C drive to D?
Wed May 14, 2025 7:54 am
It sounds like Action! might not have permission to write to your D drive. Try running the program as Administrator (right-click > Run as Administrator), and also check that your D drive isn’t write-protected or full. You might also want to check if your antivirus or Windows Defender is blocking the export.
awarenessnouns
Thu May 15, 2025 1:51 am
I also got this error recently. I asked some of my friends but no one knows how to solve them. They told me to try this forum.
pojavlauncher
PC Specification: CPU model, Graphics Card, Windows versio
Mon Sep 22, 2025 9:55 pm
If you’re unable to export or move a video from the C: drive to the D: drive, there could be several reasons. Sometimes, the issue is related to file permissions, especially if the video is stored in a protected system folder, in which case copying and pasting the file or running File Explorer as an administrator can help. Another possibility is that your D: drive does not have enough free space to store the video, so it’s worth checking the available storage. The problem may also occur if the video file is currently open in a media player or editing software, preventing it from being moved.
If you’re exporting directly from editing software, make sure the export settings point to the D: drive instead of the default C: drive. Finally, if your D: drive is formatted as FAT32, it cannot handle files larger than 4GB, so you would need to reformat it to NTFS or exFAT to transfer large video files.
AnnaBush
PC Specification: version 25H2
Fri Nov 21, 2025 8:27 am
This usually happens because of a permission or storage issue. If the D drive is write-protected, full, or missing proper folder permissions, the export will fail. Sometimes the editing software also needs admin rights to write to another drive. Checking free space, creating a new folder on D manually, and making sure the drive isn’t set to read-only often fixes it. Restarting the software after changing permissions can help too.
Eager to learn about new skills participating in different discussions.
hapox74
PC Specification: Method 1
Fri Feb 06, 2026 4:25 am
Make sure the D drive is set up with a file system that works with the OS. For example, NTFS is good for bigger files. It might not be able to handle files bigger than 4GB if it's set up as FAT32. If necessary, back up any important data and reformat the drive to NTFS.
Return to “General Topics”
