davidegold
PC Specification: i5-2500K,GTX 660ti, Win7 Ultimate x64
Action! 4.44.0
Tue Jan 07, 2025 2:53 pm
action !autostart whit windows 11 , how to disable it
thx
bonjovi
PC Specification: Windows 11 Pro
Re: Action! 4.44.0
Thu Jun 26, 2025 3:12 am
Yes, you can disable Action! from starting automatically with Windows 11. Just go to the Settings tab (Generali), and uncheck the option that says "Eseguire Action! all'avvio di Windows" (Run Action! at Windows startup). I had the same issue and this fixed it for me.
Return to “General Topics”
