Worgent
PC Specification: Windows 10
Issues with Multiple Audio Tracks in Recording
Tue Feb 04, 2025 7:10 am
I recently started using Mirillis Action! for my screen recordings, and I’m running into an issue. I want to include two separate audio tracks in my recordings, but I’m not sure how to set it up correctly. Is there a way to enable both audio tracks simultaneously during the recording?
I've checked the settings but couldn't find anything specific for this. Any help or guidance would be greatly appreciated!
samosamary
PC Specification: windows 10
Re: Issues with Multiple Audio Tracks in Recording
Fri Mar 21, 2025 4:42 am
To enable multiple audio tracks in Mirillis Action!, go to Settings > Audio and enable separate tracks for system sounds and microphone. Make sure to use MP4 format for multiple audio tracks.
dismissevery
PC Specification: Window 11
Thu Apr 24, 2025 7:29 am
Mirillis Action supports recording two separate audio tracks, but the setup can be a bit confusing at first. You can also adjust mic/system volumes independently during editing if you record separately — super useful for balancing voice and game/audio later!
jazipo
Tue May 20, 2025 6:47 am
Yes, Mirillis Action! does support recording multiple audio tracks, but the setup isn't always obvious at first glance. Make sure your default audio input/output devices are properly set in Windows and Action! before you start recording. Use MP4 format if you need compatibility with most editors, but AVI may offer better performance with dual tracks in some cases.
Return to “General Topics”
