barkerxavierr
PC Specification: i7-9700
Issues with Screen Capture Quality in Action!
Fri Feb 28, 2025 1:23 am
I hope you're doing well. I’ve been using Mirillis Action! for recording gameplay, but I’m experiencing some issues with the video quality. Here are my system specifications:
CPU Model: AMD Ryzen 5 3600
Graphics Card: NVIDIA GeForce RTX 3060
RAM: 16GB
Windows Version: Windows 10 Home (64-bit, version 21H1)
I’ve configured the settings for high-quality recording, but the final video files often look pixelated, especially during fast-paced scenes. I've tried adjusting the bitrate settings and resolution, but I'm still not satisfied with the output quality.
Has anyone else faced this issue? What settings do you recommend for achieving the best recording quality? Any tips or troubleshooting steps would be greatly appreciated!
atlas77
PC Specification: nvidia rtx 4090
Re: Issues with Screen Capture Quality in Action!
Thu Apr 10, 2025 6:40 pm
Hopefully anyone will respond to this thread because I've been having the same problem since I've been using Mirillis.
wellallnasib
PC Specification: Ryzen 3600x|RTX 3060 Ti|32GB Ram|W10|
Sun May 11, 2025 2:10 am
I have a 3060Ti I been using screen recording for a year now to record games without an issue.
I think the problem is High Settings (which forces a limit on bit rate) and I think its really low. Try manually setting bit rate which will override the Video Quality. For example I have set 60mbps for 4K recordings and everything just works. Hope this helps.
AllanGreen
PC Specification: Windows 11
Fri May 16, 2025 2:32 am
Have you tried running a test recording with OBS Studio using NVENC and similar settings. If OBS gives better results, the issue may be specific to Action!’s encoder settings or how it handles fast motion.
oliviawilde168
PC Specification: Windows 10
Wed May 28, 2025 3:16 am
Set this to 100% (Original). Your RTX 3060 can handle recording at your monitor's native resolution without a problem, which is ideal for quality.
jamesbennett
PC Specification: Windows 11 Pro
Wed Oct 29, 2025 3:20 am
I had the same problem before when I started recording my gameplay. It can be annoying when the video looks good while playing but loses quality after saving. What helped me was switching to constant bitrate and using slightly higher encoding settings. Also, try recording to an SSD instead of a hard drive if you can, it really improved the smoothness and clarity for me.
spindlycopyright
PC Specification: CPU model
Fri Oct 31, 2025 8:38 am
Hey! I’ve had the same issue with Action! before — fast motion scenes can look pixelated if the bitrate isn’t high enough or if the encoder is struggling. Try switching to NVIDIA NVENC for recording instead of CPU, and bump your bitrate to around 40–50 Mbps for 1080p60. Also, make sure “Use High Profile” is enabled under the recording settings. That combo really improved my results.
