wellallnasib
PC Specification: Ryzen 3600x|RTX 3060 Ti|32GB Ram|W10|
Lag in recordings after new update (4.45.0) (May 5, 2025)
Sun May 11, 2025 4:23 am
I been having issues with (Active Screen Recording) after latest update (4.45.0) (May 5, 2025). There is a wired lag and frame drop that feels like 20 fps for around 10 second in random parts of the video. While The game is running fine at constant 60FPS and being recorded at 60FPS with 20-30% GPU utilization. I been using screen capture + .exe exclusion method to capture old game for last year and never had any issue until now.
I have now switched back to the previous version (4.44.1) (Feb 17, 2025) and tested around 2 hours of footage. Everything seems to working just fine like before so I can confirm new update broke something in (Active Screen Recording). Did not test Game recording though and don't intend to as I do not use that mode.
OS: Windows 10
Video Card: NVIDIA RTX 3060 Ti
Memory: 16 GB (DDR4)
Monitor Resolution: 2560 x 1440
Game Problem: Any Game
Video Type: MP4
Video Bitrate : 70mbps (Forced)
roseblack
PC Specification: Windows 11 Pro (Version 23H2)
Re: Lag in recordings after new update (4.45.0) (May 5, 2025)
Tue Jun 24, 2025 2:51 am
Thanks for sharing the details — I also experienced similar lag after updating to 4.45.0, especially when using Active Screen Recording. It does seem like the update affected recording performance. Rolling back to 4.44.1 as you suggested is a reasonable solution until an official fix is ​​released.
colinkeller
Wed Nov 05, 2025 2:29 am
I’m experiencing the same issue since the 4.45.0 update — noticeable stutter and frame drops during random parts of recordings, even though in-game performance stays smooth at 60 FPS. Rolling back to version 4.44.1 completely resolves the problem, so it seems the new update affected the Active Screen Recording feature.
It might help if the dev team could check what changed in the recording pipeline or encoder handling in this release. For now, staying on 4.44.1 seems to be the best workaround.
rodneywalter
Wed Nov 12, 2025 8:10 am
I totally get what you're saying about the lag issue post-update. It's frustrating when performance takes a hit, especially during screen recording. Rolling back seems like a solid temporary fix. Have you tried reaching out to Mirillis support to see if they are aware of this and working on a fix? It might help speed up the process.
ozgamesio
PC Specification: CPU model
Thu Jan 29, 2026 3:37 am
Yeah, I can confirm this too. I’m on 4.45.0 and Active Screen Recording definitely feels off compared to 4.44.1 — random micro-stutters in the recording even though in-game FPS is locked and GPU usage looks normal. Same “feels like ~20 FPS for a few seconds” issue you described.
Rolled back to 4.44.1 and the problem disappeared instantly, so it really does seem like something regressed in the new Active Screen Recording pipeline. Haven’t tested Game Recording either since I don’t use it.
joycemills
PC Specification: Windows 10
Mon Feb 09, 2026 8:00 am
Does the 4.45.0 update introduce any changes to Active Screen Recording that cause lag and FPS drops even though the game is running smoothly?
ricardokoch
PC Specification: CPU: Intel Core i5, GPU: NVIDIA GTX 1650
Thu Mar 26, 2026 4:01 pm
Thanks for sharing this, I thought it was just my setup. Good to know the previous version still works fine.
Stability matters most.
joycemills
Tue Mar 31, 2026 9:58 am
Hey everyone! I'm really enjoying our discussion on game mechanics—especially how they relate to user engagement.
alexandernevis
PC Specification: Window 2020
Wed May 20, 2026 2:28 am
Thanks for sharing your experience! It sounds frustrating to encounter lag after the update, especially since everything was working smoothly before. It's good that you reverted to the previous version and found it to be stable. Have you tried reaching out to the support team or checking their forums? They might be aware of the issue and could provide a fix or workaround. Hopefully, they'll address the problem in a future update!
