cloakedcocktail
PC Specification: Window 10
Problem with Game Detection in ACTION! for MW2
Fri May 30, 2025 3:33 am
Hi
I play Modern Warfare 2in window, and I'd like toTime-Shift (Into captureGame Mode.
The issue is: the game only gets detected if I launch Afirst and lastACTION! stops detecting
Do you know?
Thanks in advance!
karinaaespa
PC Specification: Windows 10
Re: Problem with Game Detection in ACTION! for MW2
Fri Jul 11, 2025 1:50 am
Try launching the game after your capture software is already running—this usually helps with detection issues.
Valerie
PC Specification: 10
Tue May 12, 2026 7:33 am
What’s likely happening is: When you start ACTION! first, MW2 may switch rendering context or block capture hooks → so ACTION! stops “seeing” the game.
Nicholas97
PC Specification: Intel Core i5-10400F
Wed May 27, 2026 6:40 am
It sounds like a capture software conflict—try launching ACTION! after the game or running both as administrator so the game stays detected in windowed mode.
