bonjovi
PC Specification: Windows 11 Pro
Persistent Settings Reset on App Launch
Tue Jun 24, 2025 4:48 am
Every time I launch Mirillis Action!, all my settings reset — audio, video format, etc. I'm using an internal SSD, and reinstalling or rolling back to older versions doesn't fix it.
Is anyone else experiencing this? Any known fix or workaround?
Thanks!
golfhitgame
PC Specification: Intel Core i7-12700K
Re: Persistent Settings Reset on App Launch
Sat Sep 27, 2025 11:43 am
I’ve seen similar issues with Mirillis Action! before. Often, settings are reset because the program can’t properly save the configuration file.
athenasmith
Wed Nov 19, 2025 4:47 am
Sounds like Action! can’t save settings—check folder permissions, run as admin, or try a clean reinstall.
niukre
PC Specification: Window 17
Wed Nov 26, 2025 8:39 am
I don't use my hard drive to do new things, you can use it to play the older version just fine.
smithjohns
PC Specification: i5, RTX 1510
Thu Dec 11, 2025 11:26 am
That sounds annoying — settings shouldn’t reset like that. I’d try checking permissions or deleting the config file so it can rebuild.
sonmultiple
PC Specification: Window 11
Thu Dec 25, 2025 2:10 am
Thanks!
This usually happens because Mirillis Action! can’t save its configuration files, so try running the program as Administrator, then go to C:\Users\<you>\AppData\Local\Mirillis\Action and make sure the folder is not set to read-only, and also check that your antivirus or disk protection software is not blocking it from writing files; as a workaround, you can save your settings as a profile and load it on startup.
Ryan Curtis
PC Specification: CPU model
Fri Apr 17, 2026 3:55 am
Hey there, I've seen similar issues pop up with other software before. Have you checked if Action! has the correct permissions to write to your SSD? Sometimes that can cause it to not save configurations properly. It's also worth digging around in the Action! installation folder to see if there's a config file that's getting reset somehow. It reminds me when Granny lost her settings on her old computer, checking permissions was the key! Hope this helps.
Return to “General Topics”
