Tromen
PC Specification: 11
Lag issue when recording game screen at 1080p
Fri Aug 08, 2025 1:13 am
I'm using Action! 4.38.0 to record gameplay of games like Valorant, CS2, and GTA V. It used to be smooth, but recently when I record at 1920x1080 @ 60fps, the video often stutters, drops frames, or is out of sync with the audio and video.
My PC specs:
CPU: Ryzen 5 5600X
GPU: RTX 3060
RAM: 32GB
1TB NVMe SSD
Windows 11 Pro
I'm wondering if Action! is conflicting with a recent Windows update, or if I need to tweak something in the hardware acceleration / video codec?
ordidfluid
PC Specification: Core i7, NVIDIA, Windows 11
Re: Lag issue when recording game screen at 1080p
Sat Oct 18, 2025 4:18 am
This sounds like an encoding bottleneck rather than a hardware issue — your specs are fine.
pessimist
PC Specification: Windows 11 Pro, Intel Core i7-12700F
Wed Oct 22, 2025 4:59 am
Thanks for sharing your experience! I’m also seeing issues with the latest version of Screen Recorder – particularly with audio desync when exporting long recordings. Did you happen to test whether disabling hardware acceleration helps?
emmascott63
PC Specification: Windows 11 Pro (Version 22H2)
Thu Nov 20, 2025 8:20 am
I’ve run into a similar issue recently, and my setup is pretty close to yours, so I don’t think the hardware is the problem. What helped me was experimenting with the encoder settings in Action!. You can try switching between NVENC and CPU encoding to see if the stuttering changes — for me, the newer NVENC option gave the most stable results.
estheryu
PC Specification: CPU mode
Thu Nov 27, 2025 7:36 am
Sounds like a settings or software issue—try lowering bitrate, using NVENC, and closing background apps; also make sure drivers and Action! are up to date.
chery
PC Specification: CPU model
Sat Nov 29, 2025 3:01 am
Try switching Action!’s hardware encoder to NVENC, lowering the recording bitrate a bit, and turning off background overlays. Stutters usually come from the encoder struggling or the game running in “fullscreen exclusive.” Also check if Windows Game DVR or any other recorder is running in the background—they often cause frame drops.
JohnHolland
PC Specification: intel core i7
Wed Dec 10, 2025 2:08 am
It sounds like something recently changed in your setup, especially since your hardware is more than capable of smooth 1080p60 recording. Action! has had issues in the past after certain Windows updates, so it’s definitely worth testing a different codec or switching between hardware (NVENC/AMD/Intel) and software recording to see if the issue persists. Also try disabling Background Recording in Windows Game Bar, since it can conflict with third-party tools. Another good test is recording to a different drive or lowering the recording buffer just to rule out I/O hiccups. If the stutters only started recently, it’s likely a software conflict rather than your hardware struggling.
Malcolm
PC Specification: Windows 10 64-bit
Wed Mar 11, 2026 1:17 am
I have the same issue recording at 1080p60. After recent Windows updates, Action! sometimes drops frames and causes audio sync problems.
