annehathaway
PC Specification: Windows 11
Issue Connecting Twitch Account in Mirillis Action
Thu Sep 04, 2025 4:22 am
Hi everyone,
I’m having trouble connecting my Twitch account to Mirillis Action. Although I can log into Twitch via browser without issues, Action’s Accounts Manager won’t complete the login and keeps showing me as “not connected.”
YouTube streaming works fine.
I’ve updated to the latest version, reinstalled the software, and double-checked my network—no change.
I also tried re-adding the account and checking for firewall/antivirus conflicts.
Has anyone else faced this with Twitch integration? Is there a known fix, or should I use the manual stream key as a workaround?
Many thanks for considering my request.
errifypeaceful
Re: Issue Connecting Twitch Account in Mirillis Action
Tue Dec 02, 2025 3:12 am
Hi everyone,
A common issue right now with Mirillis Action — Twitch changed parts of its authentication/API, and older (and even recent) Action builds often fail to complete the OAuth login, leaving the account stuck on “not connected.
berateracer
PC Specification: Windows 10
Tue Dec 16, 2025 1:19 am
Hi everyone,
I’ve seen a couple of people run into this with Action and Twitch specifically, so you’re definitely not alone. From what I understand, it’s often an OAuth/authorization issue on Twitch’s side rather than anything you’re doing wrong, especially since YouTube works fine. Using the manual stream key is a solid workaround and tends to be more reliable anyway. If you want the account linking to work properly, it might be worth opening a ticket with Mirillis support, as they sometimes need to update their Twitch integration when Twitch changes something.
jipafah845
PC Specification: CPU model
Thu Feb 19, 2026 4:05 am
I’ve run into this before, and using the manual Twitch stream key in Action usually works reliably while waiting for Mirillis to fix the account-manager login integration bug.
Return to “General Topics”
