andrastiq
PC Specification: Windows version 1903
action not detecting 5070ti?
Wed Sep 24, 2025 7:01 pm
My hardware acceleration option is only showing AMD AMF H264 and not my 5070ti, i know this is an action issue because i dont have this problem with bandicam and obs. Any solution or update? my gpu is GeForce RTX™ 5070 Ti GAMING OC 16G
davidsolano
PC Specification: Windows 11 Enterprise LTSC
Re: action not detecting 5070ti?
Fri Nov 07, 2025 2:51 pm
Did you try reinstalling the NVIDIA drivers or checking if Action! supports the 5070 Ti yet? If it's just a compatibility issue with the newer RTX cards.
GyKrisz
PC Specification: AMD R9 9900X, RTX 5070 Ti, Win11 25H2
Mon Nov 10, 2025 6:22 pm
I have same issue. Action does not detect my Gigabyte RTX 5070 Ti GPU.
Users browsing this forum: No registered users and 52 guests
