Fire Marshal Bill
PC Specification: Windows 10 1909, Intel Core i7 CPU
In Splash 2.7.0.0 progress bar and font question
Wed Oct 08, 2025 8:58 pm
Is there any way to:
1. Make the running time on the progress bar bigger?
2. Make the fonts on the progress bar and various other menus to be made bold?
After using VLC Media player for two decades, I finally found THE best player having almost all the features I want and love. THANK YOU, Mirillis.
I am hoping you can tweak it to achieve the above two requests, if possible.
ordidfluid
PC Specification: Core i7, NVIDIA, Windows 11
Re: In Splash 2.7.0.0 progress bar and font question
Wed Oct 15, 2025 2:17 am
Totally agree! bigger running time and bold fonts would make the interface feel more polished and accessible. It’s awesome that Mirillis keeps improving with user feedback like this.
DarrenClemons
PC Specification: Intel Core i7-12700K
Wed Oct 22, 2025 8:37 am
Bigger running time and bold fonts on the progress bar would make the interface even more readable, especially from a distance. Great suggestions — hopefully the devs consider adding them in a future update.
bettylim
PC Specification: 12 CPUs, 3.6GHz, Windows 11 Pro
Mon Nov 10, 2025 4:41 am
You can try changing your Windows scaling or font settings — it slightly increases the on-screen size in Splash. But as far as I know, there’s no direct option in the app yet.
emmascott63
PC Specification: Windows 11 Pro (Version 22H2)
Tue Nov 18, 2025 9:44 am
I completely agree with both of you! Making the running time larger and using bold fonts would definitely improve readability and overall user experience. Splash is already fantastic, but these tweaks would make it feel even more polished and accessible, especially for longer viewing sessions or when watching from a distance. Fingers crossed the devs consider these suggestions in the next update!
jakonhanesh
Thu Nov 20, 2025 12:10 pm
As far as I know in 2.7.0.0, there isn’t a built-in option to change just the progress bar font size or make those specific texts bold. The UI is mostly fixed in terms of font styling.
A couple of things you can try in the meantime:
System scaling/DPI – increasing Windows display scaling can make all UI elements (including Splash’s time display) a bit larger.
Feature request – your two ideas (bigger running time + bold fonts on the bar/menus) are very reasonable quality-of-life improvements. It might be worth sending them directly to Mirillis support or posting in their feature request section so the devs see it clearly.
You’re definitely not the only one who’d appreciate clearer, larger time and text, especially on higher-resolution screens.
adventvoles
PC Specification: CPU model
Thu Apr 09, 2026 7:33 am
Both of your suggestions—a longer running time and bold fonts on the menus and bar—are really sensible ways to improve the quality of life. For the developers to view it clearly, it could be worthwhile to publish them in their feature request section or send them straight to Mirillis support.
Return to “Splash 2.0”
