hneidernigel
PC Specification: Windows 11 Pro 64-bit
Optimize screen recording performance when using Mirillis Action! on low-end devices
Tue Dec 02, 2025 4:14 am
Hi everyone,
I've recently been trying to use Mirillis Action! to record and livestream, but I'm experiencing lag when recording heavy games or running multiple applications at the same time. My device isn't too powerful (i5 CPU, 8GB RAM, mid-range GPU), so I'd like to ask for experience from the community:
What screen recording settings help optimize performance while maintaining high video quality?
Are there any tips to reduce lag when recording and livestreaming at the same time?
Anyone who has used Action! on a low-end device, is there any effective plugin or trick?
I think this is also a common problem for many new users of Action! and would love for everyone to share their real-life experiences.
Thanks everyone in advance!
AnnaBush
PC Specification: version 25H2
Re: Optimize screen recording performance when using Mirillis Action! on low-end devices
Thu Dec 04, 2025 7:37 am
Running Action! on a lower-end setup can be tricky, but small adjustments make a big difference. Lowering the recording resolution to 720p, using a moderate bitrate, and switching to hardware encoding usually improves performance without ruining image quality. Closing background apps and locking the game to a steady FPS also helps reduce stutter. If you stream and record at the same time, keep both settings light so the CPU doesn’t spike. Action! works fine on older hardware as long as the settings match the device’s limits.
Eager to learn about new skills participating in different discussions.
divechemical
PC Specification: Win10
Thu Dec 04, 2025 8:17 am
Closing background apps and using “game mode” in Action! can also help reduce lag a lot.
bobbywalker
PC Specification: Window 11
Thu Jan 15, 2026 4:22 am
Hi! On a mid-range setup like yours, I found that using hardware encoding (GPU), lowering resolution or FPS slightly, and closing background apps really helps. When streaming and recording at the same time, reducing either the recording quality or frame rate prevents lag. Saving temporary files to an SSD and enabling “Prioritize performance” in Action! also makes a noticeable difference.
Vitory102030
PC Specification: Windows 11 Pro 22H2, Intel Core i7-12700
Mon Jan 19, 2026 12:11 pm
Lowering the recording resolution can significantly reduce lag on mid-range devices. Many users find that recording at 720p instead of 1080p keeps video smooth while still maintaining good quality. Disabling unnecessary overlays and background applications also helps Action! run more efficiently.
Return to “General Topics”
