krsolecheta
PC Specification: i9 12900f, 64gb ram, rtx 4060ti,win11
splash 2.7 crash windows 11
Mon Dec 08, 2025 1:16 am
have windows 11 25h2 26200.7309, i9 12900f and rtx 4060ti
since i've installed nvidia drivers 591.44
splash don't work,
I try to open it by double-clicking; the window appears but closes automatically. Is anyone else experiencing this? Thanks.
Kadett
PC Specification: I9 11900k RTX 3080 Win 11 25H2
Re: splash 2.7 crash windows 11
Mon Dec 08, 2025 12:42 pm
Same here. Since the new Nvidia driver 591.44, Splash starts briefly and then immediately terminates without an error message.
krsolecheta
Tue Dec 09, 2025 6:49 am
Thank you so much for confirming that I'm not the only one.
MNM
PC Specification: AMD RYZEN 9 5900X NVIDIA 2060 12GB WIN10
Thu Dec 11, 2025 11:38 am
I can confirm that NVIDIA driver 591.44 causing player to not run. Studio driver 576.80 has no issue to run the player.
Imogen
PC Specification: windows 11
Sat Dec 13, 2025 6:46 am
This looks like it could be a compatibility issue with the latest Nvidia 591.44 drivers on Windows 11 25H2. A few users have reported similar behavior with older Splash builds after recent driver updates. You could try rolling back to the previous Nvidia driver to confirm, or reinstall Splash and run it once as administrator. If that does not help, reporting this to Mirillis support with your exact driver and Windows build would be a good idea so they can investigate and patch it.
Kadett
Thu Dec 18, 2025 2:17 pm
I explained this to support on the very first day and haven't received a reply yet. Of course, I also tried running as administrator and reinstalling. Splash only works with drivers older than 591.44
UrGodsRDead
PC Specification: AMD Ryzen 5, MSI B450, Win11 25H2
Thu Jan 15, 2026 1:59 pm
Registered a new acct here to confirm the same. Win11 x64 25H2 OS build 26200.7623, MSI B450 GPU, GeForce driver 591.74 (Jan 5th, 2026).
SplashProFanFromBY
PC Specification: 5600x 2060 SUPER Win11
Sat Jan 17, 2026 10:17 pm
After installing NVIDIA driver 591.74, Splash Pro video player consistently crashes on startup. (Rolling back to the previous version fixes the issue).
DeathC0veR
PC Specification: i7 - 14700K, RTX4080, Windows 11
Mon Jan 26, 2026 1:15 pm
Hi! Easy. To solve this annoying problem and continue using this wonderful player, simply add any character before the name of the libmfxsw32.dll file. For example, !libmfxsw32.dll. Success!
zbotdll
PC Specification: i5 12gen RTX3050 Win11
Mon Feb 09, 2026 11:12 pm
mine also when my laptop updates and nvidia drivers were updated.. when i tried to open splash. it will automatically closes
already tried to changed all possible settings via properties like "run compatibility using win8"
"run as admin" etc etc. i hope they could resolve this issue
Return to “Splash 2.0”
