johnfleck
PC Specification: 12 CPUs, Windows 11
Audio gradually goes out of sync on long recordings
Tue Jan 06, 2026 2:28 am
Hi everyone,
I'm having an issue with Action! that I can’t seem to solve on my own. When I record longer sessions (usually 30–60 minutes), the audio slowly goes out of sync with the video. At the beginning everything is perfectly fine, but as the recording continues, the audio starts lagging behind more and more.
This happens both with game recordings and desktop recordings.
My PC specs should be more than enough (stable FPS in-game, no CPU or disk spikes during recording).
Has anyone experienced audio desync like this with long recordings in Action!?
visitflutter
PC Specification: CPU model
Re: Audio gradually goes out of sync on long recordings
Wed Feb 25, 2026 2:47 am
Has anyone else encountered this kind of audio desync when listening to lengthy Action! recordings?
bobbywalker
PC Specification: Window 11
Tue Mar 03, 2026 1:25 am
Yes, a few people have run into this with longer recordings in Action!. It is often related to audio sample rate mismatch (for example 44.1 kHz vs 48 kHz) or variable frame rate recording. Try setting both Windows sound settings and Action! to 48 kHz, and if possible enable constant frame rate recording. Also make sure your recording drive is fast enough and not close to full.
Hopefully that fixes the gradual desync.
fnfunkin
PC Specification: i5-10400F
Wed Mar 18, 2026 2:25 am
I’ve run into this before, and in my case it was related to audio sample rate mismatches between the recording software and Windows settings, which caused gradual drift over longer sessions. It might also be tied to variable frame rate recording, which some editors struggle to sync properly. Locking both audio settings and using constant frame rate helped reduce the issue significantly.
monthlyglug
Thu Jul 16, 2026 4:05 am
it may be related to variable frame rate recording, which some editors find difficult to synchronize. The problem was considerably lessened by utilizing a fixed frame rate and locking both audio options.
ilyacolton
PC Specification: CPU i5, win 11
Thu Aug 13, 2026 3:30 am
I’ve encountered audio sync issues during long recordings as well, particularly with software that demands high resource allocation. It’s crucial to ensure your system and settings align to prevent such discrepancies. Addressing these concerns is vital, especially for content creators striving for professional quality in their work. The troubleshooting tips shared here are invaluable!
