insecureeight
PC Specification: Window 10
No Microphone Audio in Recordings
Tue Mar 31, 2026 4:44 am
Hello everyone,
I’m currently experiencing an issue with Mirillis Action! when recording screen videos. Even though my microphone is enabled and the software clearly detects input (the audio levels are showing activity), my voice does not appear in the final recorded video.
I’ve already checked the Audio Settings and confirmed that:
The correct microphone is selected
The input volume is properly adjusted
Despite these settings, the recorded video still has no microphone audio at all.
Has anyone else run into this problem before? If so, I would really appreciate any advice or solutions.
Thanks in advance for your help!
Re: No Microphone Audio in Recordings
Thu Apr 02, 2026 6:28 am
Make sure that "Record microphone into separate audio track" option is disabled.
MagonDe
PC Specification: Ryzen 9 9950X3D, GeForce RTX, Win 11
Fri May 01, 2026 10:54 am
Hey! I've been running into some performance hiccups lately, so seeing these specific settings for Action! is super helpful. It really clears up how to optimize the recording without losing quality. Definitely makes things run much smoother!
visibleăer
PC Specification: Windows 10
Wed May 27, 2026 3:42 am
That's a frustrating issue, I've dealt with similar audio problems before. Sometimes a fresh driver install or checking default Windows sound settings helps. It's like trying to navigate a tricky snake game, you think you have it all figured out, but there's always a hidden snag.
jasperwilde11
PC Specification: Windows 11 64-bit, Intel Core i5, NVIDIA
Tue Aug 25, 2026 8:45 am
I had a similar issue once. In my case, checking the Windows microphone permissions and making sure the correct input device was selected in Action! fixed it. Also worth checking whether the microphone is being recorded to a separate audio track.
Return to “General Topics”
