rosebl22
PC Specification: Windows 11 (64-bit)
Action! crashes when recording HDR + DLSS
Wed Apr 08, 2026 8:30 am
Hi everyone, I’m having a specific issue with Action! Screen and Game Recorder when trying to record gameplay with HDR enabled and DLSS turned on in-game. Every time I start recording, the software either crashes or the recorded file ends up completely black, while the audio is still there.
My setup is Windows 11 with an RTX 3060, and this only seems to happen in newer games that support both HDR and DLSS. If I disable HDR, recording works fine, but I’d really like to keep HDR quality.
Has anyone experienced this or found a stable setting to record HDR gameplay properly in Action!?
Re: Action! crashes when recording HDR + DLSS
Thu Apr 09, 2026 7:20 am
Hello. Can you give us specific game titles that have this problem.
marktuan
PC Specification: Intel Core i7-12700K
Tue Apr 21, 2026 1:44 am
I’m having the exact same issue here. On my setup (Windows 11 + RTX 3070), whenever I try to record with HDR + DLSS enabled, Action! either crashes or I get a black video with only audio. If I turn off HDR, everything works normally.
Tested so far in games like Cyberpunk 2077 and Hogwarts Legacy — both show the same behavior. Could you please check if this is a known limitation or something that can be fixed in a future update?
Thanks!
