annasm
PC Specification: CPU: Intel Core i5-12400F
Splash 2.0 forgets subtitle style after restart
Mon Jun 29, 2026 9:55 am
Hi everyone,
I'm using Splash 2.0 on Windows 11, and I noticed that every time I close and reopen the program, my custom subtitle settings (font size, text color, and outline) are reset to the default values. The video playback settings are saved correctly, so it seems to affect only subtitles.
Is there a configuration file or option that controls subtitle preferences, or is this a known issue with Splash 2.0? I'd like the subtitle style to stay the same between sessions without having to adjust it every time.
Thanks!
Return to “Splash 2.0”
