totalv
PC Specification: i7, nVidia GTX275, Win 7 x64 ent.
BestQuality enabled, but brightness and contrast ineffective
Thu Feb 16, 2012 2:25 pm
I've tried to adjust brightness, with like +/-50 to see the effect, but nothing changed visually!!
* Hardware Acceleration Enabled (nVidia PureVideo)
mattisdada
PC Specification: i7 2700k@4.3ghz, nVidia 460 , 12TB* HDD
Re: BestQuality enabled, but brightness and contrast ineffec
Tue Mar 06, 2012 12:07 pm
Works perfectly fine for me. But you could have video overlay enabled. In your nVidia control panel go to:
"Adjust Video Image settings". And make sure the "Use video player settings" is set to both options.
(On Windows 7, just type nVidia in the start menu and the nVidia control panel should appear).
Hope that helps :)
Thu Mar 22, 2012 12:35 am
We have tested this on the same PC spec as yours and works fine.
Please make sure like mattisdada said to check settings in grpahics card control panel.
totalv
Thu Mar 22, 2012 11:22 am
thanks guys, that did the trick.
Or I could force video overlay in settings, but that disables Windows Aero effect.
