Deez
PC Specification: i7;palit gtx460 sonic platinum;win7x64
Need Help!! BF3 (INVESTIGATING)
Sat Feb 18, 2012 3:51 pm
Hi guys. need your help. stumbled upon your product and was really concerned them. Put trial and included a record in the game, does not drop fps is as stated, the program is like, but there is one issue. When I look shot video and export it, and I do look through it again I notice that the video shot for a split second FPS drops to zero and restored. But in the game FPS drops no, only when viewing or exporting.
how to solve the problem?
My system: Intel Core i7 870, Palit GTX 460 Sonic Platinum; Win 7 x64 Ultimate.
Programm test in Battlefield 3
link the promlem on youtube: http://www.youtube.com/watch?v=OIaogMFU ... e=youtu.be
P\S Sorry my english is bad ^^
Re: Need Help!! BF3
Sun Feb 26, 2012 9:32 pm
Does this problem occur only in BF3?
Did you try any other games?
Deez
Re: Need Help!! BF3 (INVESTIGATING)
Mon Feb 27, 2012 8:17 am
The problem was only in BF3.
Solved the problem by turning on vertical sync in the game.
If, I note somewhere else, tell in this thread
Deez
Fri Mar 02, 2012 3:33 am
if use the vertical sync, and above 60 FPS is not raised.
If vertical sync is disabled, then again the problem with viewing and rendering.
as a 2nd option helps reduce graphics settings on nimimum, but not exactly sure.
Can there still any solutions to this problem?
Sun Mar 11, 2012 9:52 pm
Deez wrote:if use the vertical sync, and above 60 FPS is not raised.
Thank you very much for information about Vsync options.
We are still investigating this, we cannot reproduce problem at the moment but will check this on PC with gtx460 soon and will keep you informed.
