woostank
PC Specification: amd 64 x2 3600+ 2GB ram, ATI X1950 GT
Splash Lite crash on startup
Mon Jan 04, 2010 2:27 pm
Thx for this excellent program! :D
I have the previous version installed on my Win 7 x64 laptop and it run smoothly w/ no problems.
I just installed the current version 1.1 on my Win xp sp2 desktop. Installation went smoothly but every time I try to run the program I get the following error:
Critical error during initialization
This application cannot be executed
I've tried to uninstall/reinstall and also the repair option but nothing has worked so far.
Thx for your time.
Watchman
Re: Splash Lite crash on startup
Mon Jan 04, 2010 9:49 pm
Hello woostank!
This problem might be related with WinXP SP2. Currently Splash Lite requires WinXP SP3 and possibly (but we need to verify this) some functionality is missing in WinXP SP2 that causes this error during Splash startup.
Thanks for your feedback. We will post a solution to this problem as soon as it is fixed.
Best regards.
exthemax
PC Specification: compaq presario v6328ea win7ult 32 bit
Thu Jan 14, 2010 1:58 pm
woostank wrote:Thx for this excellent program! :D
Thx for your time.
I have the exact same problem on my compaq v6328ea running on win7 ultimate 32 bit. I have the final updates, and couldn't make the program work.
Thanks.
Thu Jan 21, 2010 12:37 am
We are invastigating this issue and will keep this topic updated.
Thank you for reporting problems.
SFisher
Fri Jan 22, 2010 7:49 am
I have similar problem.
Windows XP SP3
bozo
PC Specification: i7 2600k, GF GT240, Win7 x64
Fri Jan 22, 2010 8:38 am
I can confirm similar problem.
Even without open a movie when I press "I" (info tab) button program crashes.
open player -> press "I" button
other situation:
Open the movie (in my case apple trailer) the movie was played properly. Press "I" for info and it working then stop the movie. Info key still working but when you right click on player the Information in inactive.
Missing file extension:
open file button -> there is no .hdmov ext in stream list
Thu Jan 28, 2010 8:46 pm
bozo wrote:I can confirm similar problem.
other situation:
Thanks for your detailed feedback, it should be fixed with next Lite release.
SFisher
Thu Feb 04, 2010 1:38 pm
No one answered my question.
Thu Mar 25, 2010 10:46 pm
SFisher wrote:No one answered my question.
Hi, please post your PC spec: CPU model, graphics card model, optional: graphics drivers version.
Thanks.
Nowski
PC Specification: Dimension DM061,Geforce 8600,Vista SP2
Sun Apr 11, 2010 4:46 am
Hello, I am having a similar problem. I have no idea what to try.
I am running a Dell Dimension DM061, on Vista 32 SP2, with a NVIDIA Geforce 8600 GT
