KuKiii9
PC Specification: Acer 7750g
FIC format...
Wed Feb 22, 2012 3:34 pm
Hello everyone.
I buy this program and everything allright, but my videos when upload on Youtube isn't work... Why?
I don't know how convert any video from this program... FIC this is really bad format. Only Action Player working with this files :/ ...
This is all true ? Maybe I doing something wrong ? Please tell me how do it avi,mp4 or something only no FIC ... :evil:
Best wishes.
Re: FIC format...
Sun Feb 26, 2012 9:33 pm
KuKiii9 wrote:Hello everyone.
Best wishes.
Hi, just right click on the recording and select export.
You can export it directly to youtube or facebook.
There is also a button below recording list that exports selected recording.
KuKiii9
Re: FIC format...
Fri Mar 02, 2012 2:11 pm
Ok thanks ;)
But I have new problem... why when i convert video Sound mute... ? In .fic format all is good .
Very good program, but where is sound ???
What is the best performance to convert?
broascadilie
PC Specification: Nvidia 9800 GT,1GB Ram,4 GB RAM,OS=7-x64
Re: FIC format...
Sat Mar 03, 2012 4:21 pm
Why .fic format ? Its unfair,because u cant use that in other converting tools ! In this matter Mirillis forces u to use their own integrated converted from the app ! NOT RIGHT ! NOT RIGHT ! NOT RIGHT ! Mirillis do something ! Or there is an option that i didnt seen that the recored file to be in someother format ?
LDK
PC Specification: Quad Core Intel, NVIDIA GTX 680
Re: FIC format...
Sun Mar 04, 2012 5:34 pm
KuKiii9 wrote: why when i convert video Sound mute... ?
You need to play the exported file in a media player program which supports AAC audio.
If all else fails, click on the "splash" link on top of this page - the Splash PRO player made by the very same people does an excellent job of exactly that. :)
KuKiii9
Re: FIC format...
Sun Mar 04, 2012 8:32 pm
Ok... but when I upload video on Youtube that the same effect... no sound ;/
Re: FIC format...
Sun Mar 11, 2012 9:53 pm
KuKiii9 wrote:Ok... but when I upload video on Youtube that the same effect... no sound ;/
Do you have completly no audio in exported file or it dissapears after few seconds?
What mic settings do you have in Action! video rcording tab, is it "do not record"?
broascadilie wrote:Why .fic format ? Its unfair,because u cant use that in other converting tools ! In this matter Mirillis forces u to use their own integrated converted from the app ! NOT RIGHT ! NOT RIGHT ! NOT RIGHT ! Mirillis do something ! Or there is an option that i didnt seen that the recored file to be in someother format ?
FIC because it is our own optimized format that allows to record with low cpu usage, quite low hddd usage and good video quality.
We are already working on few solutions that will make using FIC files easier.
broascadilie
Re: FIC format...
Sun Mar 11, 2012 11:31 pm
This is some great news,finnaly ! :) All that i want is to DIRECTLY use that fic file file in some 3-rd party converting tools ! DIRECTLY not in your embded converting tool
gombazo
PC Specification: AMD Phenom X6 3.8GHz, HD5850 Crossfire
Re: FIC format...
Sun May 27, 2012 10:20 pm
I want Ati Stream support :(
WujekRada
PC Specification: i5 2500k gtx580 win 7 64 bites
Re: FIC format...
Sun Jun 10, 2012 3:09 pm
Yeah, converting to mp4 is killing quality. I want to have very good quality not a small size of video :-[
