marfpilf
PC Specification: Windows 7 x64, E8500, ATI HD 5850
Question about motion2
Tue Feb 01, 2011 12:37 am
Does motion 2 get better if you have a better CPU. Does it perform better with video card doing the decoding?
Nielo TM
Re: Question about motion2
Sat Feb 05, 2011 3:14 am
Yes and yes
Open task manager and see it is maxing out the CPU
Sun Apr 10, 2011 10:26 pm
When cpu is on the edge of performance for Motion2 then it may skip to work sometimes, so when there is more power available then yes it will work better.
But if it is working ok then in example 30% more power will not make it better.
If there is enough power (4 cores) then you can enable ULTRA 1080p option to get better results.
