uzerrr
PC Specification: Phenom X4 Win7x64 6850
[QUEST] Hotkeys
Mon Mar 05, 2012 8:41 am
Is there any way to change hotkeys?
I would like to make something ALT-F9, but maybe I am doing something wrong....I just can't.
From what I can see there is only option to swap between function keys, which is wrong, becouse PC games use function keys for saving, loading and other in-game functions...
Cheers!
Re: [QUEST] Hotkeys
Sun Mar 11, 2012 9:53 pm
Hi, open settings/hotkeys, move mouse over the edit box with a shortcut (icon with keyboard key will show up) and press your key combination. Not all keys are allowed currently but alt+f9 should work fine.
SkYzKozuYT
PC Specification: Windows 10
Re: [QUEST] Hotkeys
Fri Aug 11, 2017 1:39 am
I recently changed my recording hotkey to F1, but wanted to change it back to F9. I tried changing it, but F9 doesn't work. There are no other hotkeys with F9.
Re: [QUEST] Hotkeys
Fri Aug 11, 2017 5:53 am
1. Uninstall Action!
4. Remove Action! catalog.
5. Reboot your PC.
