teamka42
PC Specification: Intel Q6600, AMD HD5450, Windows 7
Time jump buggy
Mon Mar 05, 2012 1:06 pm
hi, ive been using splash pro for quite a while now and i really like all the extra features that are not available in other players. Its just that for me the time jump is a little bit buggy.. for example, when i click the forward jump (i set to 5 sec) it'll jump forward 5sec no prob, then if i want to jump backward, it wont go 5sec back.. it'll loop the current frame if i pressed the button repeatedly. forward jump after that will sometimes cause the same loop effect randomly, sometime it happens sometime it wont..
i review video clips alot and theres no time to watch them properly in my case.. so i jump quite alot..
other players that's good at time jumping (gom and potplayer). at current state, the time jump in splash pro is comparable to VLC.
hope splash pro can improve on this..
TQ
Re: Time jump buggy
Thu Mar 22, 2012 12:34 am
Hi and thanks for a feedback.
This is caused by rare key frames in the video file.
Double press of left arrow should solve the problem but we are aware this is not comformtable. We plan to improve this in future versions.
