bashar_88
PC Specification: Hardware & Software
Help! Help! Help! - Win XP (SOLVED)
Tue Mar 06, 2012 8:38 pm
Hi , I have problem today with "mirillis action" I have already install it but when i run this program this error appear
The Folder 380 in the Dll "COMCTL32.dll" is not found
I have Windows® XP(SP3) . How can I resolve this problem . Help me please i wish u to read ur respond soon because
i need it Urgently....
hector980
PC Specification: Windows 7 SP1 64-Bits
Re: Help! Help! Help!
Fri Mar 09, 2012 1:36 pm
If you read the minimum requierements for this pogram it says Windows Vista, it doesn't run on Windows XP
Re: Help! Help! Help! - Win XP (SOLVED)
Sun Mar 11, 2012 9:55 pm
We are sorry but like hector980 said, Action! does not support Windows XP and we do not plan to add support in the nearest future.
bashar_88
Sat Mar 31, 2012 6:16 am
I had already installed windows 7 , now when i run this program on windows 7 an error window appear and said that i have problem called " Appcrash " as this picture below:-
http://imageshack.us/photo/my-images...ashaction.jpg/
http://img694.imageshack.us/img694/4...rashaction.jpg
now what can I do in this case please?
bashar_88
Sat Mar 31, 2012 6:20 am
if the first link for the problem pic is not working this is another one :-
http://imageshack.us/photo/my-images/20 ... ction.jpg/
venessakfultz
PC Specification: windows7
Mon Apr 02, 2012 12:14 pm
Windows XP is by far best operating system and that this software is friendly with XP that should have to be changed because windows Vista is not that friendly as WinXP.
