Del
PC Specification: win7
Is it possible to run multiple copies of the program?
Sun Mar 11, 2012 2:37 pm
lluvia
PC Specification: Intel, NVIDIA, W7
Re: Is it possible to run multiple copies of the program?
Mon Mar 12, 2012 11:53 pm
Del wrote:Is it possible to run multiple copies of the program?
By default it is not possible, but you can copy Splash exe file, rename it and then start it multiple times.
We do not enable to run multiple Splashes because of hardware resources problems, but if you wish you can run several Splashes at a time.
General Forum Support
Del
Tue Mar 13, 2012 7:24 pm
thx
Return to “General Topics”
