xdnbkingx
PC Specification: Intel i7 3770k, GTX 670, Windows 7 64bit
Recording issue....
Sat Mar 17, 2012 11:30 am
The program itself is amazing and is the best ive used and no change in performance BUT look at this video...
http://www.youtube.com/watch?v=nkZgOqBQDQA
Even on 1080p it doesn't look right... It isn't very clear. Can somebody please help me with the settings, Am i doing something wrong?
Thanks!
vivan
Re: Recording issue....
Sat Mar 17, 2012 4:28 pm
It's youtube, it has crappy video quality and there is nothing to do with it.
So about which video quality are you talking about: recorded video (.FIC), exported video (.mp4) or uploaded to youtube?
If first - .FIC is almost lossless... Although higher qulaity mode is planned as I know. But I think that this new mode wouldn't affect quality of exported video.
If second - what settings are you using? You can increase bitrate, or/and increase "video quality" (low > normal > high).
If third - it's youtube.
PS Vita, Nokia N8
xdnbkingx
Sat Mar 17, 2012 6:40 pm
vivan wrote:It's youtube, it has crappy video quality and there is nothing to do with it.
Well i have the trail version and i can only have it on Normal quality.... Could that be the reason? and i upload it straight to Youtube HD via the App. So if i export it 1080p high THEN upload it to Youtube it will be better?
And should i use Multicore and CUDA?
jasonblitz
PC Specification: windows 7
Sat Mar 24, 2012 10:41 am
Yes, the quality doesn't like to be of 1080p the settings must have to be changed or else have to download the new you tube HD, i hopeso that would solve our issue.
xdnbkingx
Sun Mar 25, 2012 4:25 pm
jasonblitz wrote:Yes, the quality doesn't like to be of 1080p the settings must have to be changed or else have to download the new you tube HD, i hopeso that would solve our issue.
How do i download the new Youtube HD ? i have done another recording in 1080p and exported it HIGH and then uploaded it to Youtube and its really good BUT its a big file...
