Splash PRO 1.5.0
Thu Feb 24, 2011 2:58 pm
Splash PRO 1.5.0 is now available!
What's new in Splash PRO 1.5.0:
* Motion² improvements (up to 30% lower avarage cpu consumption)
* LightBoost (GPU accelerated mode) improvements
* HD audio codecs bitstreaming improvements
* DTS audio decoding improvements
* LPCM audio decoding improvements for MKV and VOB files
* 3.1 audio support improvements
* MP3 audio decoding improvements
* DV-AVI video decoding added
* MPEG-1 video decoding added
* VC-1 hardware accelerated video decoding improvements for NVIDIA
* PGS in MKV support added
* Automatically resume playback option added
* User interface improvements for high DPI Windows settings
* Windows screensaver management improvements
* Next/previous file opening improvements for Windows Vista and 7
* Windows 7 like recent files taskbar menu for WIndows Vista and XP
* Playlist searching improvements
* Playlists improvements
* AVCHD playback improvements
* Moving the player window by dragging video area added
* New keyboard shortcuts added
- ~/1/2 - 50%/ 100%/ 200% video view
- Shift+X - close application
- Ctrl+L - load subtitles from file
- Ctrl+F - open folder
* Translations improvements
* Stability improvements
* GUI improvements
rbr303
PC Specification: i7+GTX470+7, intelG45+win7
Re: Splash PRO 1.5.0
Thu Feb 24, 2011 3:54 pm
For MKV: DTSHDMA bitstreaming works now (GTX470), PGS subtitles too.
I noticed also quality improvement for M2. Nice update. Thanks :!:
Ralf
PC Specification: Intel E6850, Nvidia GTX 260, Win7 64 Bit
Thu Feb 24, 2011 6:03 pm
thank you :D
crl2007
Thu Feb 24, 2011 7:36 pm
Great improvements but I'm kinda disappointed because subtitle tags are still not working. I was kinda hoping to see italics and color tags.
falco313
PC Specification: Phenom II, Ati 4890, Windows 7 x64
Thu Feb 24, 2011 9:32 pm
This is great but, seriously, we need "basic" fixes.
- Ability to successfully associate Splash PRO with media files through windows (windows 7 here) control panel or from the program options itself (both things are needed).The option given during installation does not work (at least in win 7), so the association must be done the rudimentary way (open this file with - check always - open), which is not acceptable these days :lol:
- Subtitles, sometimes they stop working for a few seconds showing numbers instead (time marks of the subs file?) This error is not present in other media players, so there must be a little problem here... (I normally use .srt)
For me, these are the most annoying bugs/improvements...
EmZvr
PC Specification: Acer TimelineX 3820TG
Thu Feb 24, 2011 9:37 pm
There's a GUI issue still not being fixed. There is a problem with the pause/play animation. Here's a picture:
I have WIndows 7, reoslution 1366x768 and 125% DPI
Terry
Thu Feb 24, 2011 10:37 pm
Very nice updates.
Picture quality with Motion2 is better now.
Good to see auto resume working. Thanks!
Will check audio bistreaming later.
BTW, how do you check average CPU consumption?
Using task manager can see motion2 taking less CPU resources but it is hard to say how much less.
lbamda
Thu Feb 24, 2011 11:23 pm
Splash PRO 1.5.0 - Thanks, the big work has been spent! But for me on this version has not work hardware deinterlacing (ATI 5770 Win7 10.12 drivers H.264/AVC 1080i/60i source in mkv) - On the version Splash PRO 1.4.0 all was excellent. From the noticed it has started to be decoded DTS-HDMA, but TrueHD it is not decoded yet. At all doesn't play Wav audio files :? .
Also it would be desirable to see support 4.0 (quadro) speakers configuration...
nunatak
Fri Feb 25, 2011 1:00 am
Thanks!
Any news about the Export version?
gmit
Fri Feb 25, 2011 10:00 am
Speed improvement is clearly visible on my quad Athlon system. Very nice work!
