htctyo
PC Specification: Q9450, ATI5450, Win7
Motion 2 eat too CPU usage
Fri Mar 04, 2011 2:11 am
I buy Splash Pro 1.5 but I find that when I play 1080P movie and turn on motion2 , my Q8200 CPU cannot handle smoothly. but 9450 CPU is OK. I think that it is not CPU problem. I hope that you can make a improvment , so it can be fine in Q8200. because it is also Quard core CPU.
vivan
Re: Motion 2 eat too CPU usage
Fri Mar 04, 2011 1:42 pm
Q9450 is about 25% faster than Q8200.
Plus hardware accelerated video decoding ("GPU" icon on the bottom left) can make difference.
So... it could be CPU problem.
What is CPU usage with and without motion2 on same video on both systems (with Q8200 and Q9450)?
PS Vita, Nokia N8
murphy
PC Specification: C2D E3400@3Ghz--Nvidia GTS 250--W7 64Bit
Sat Mar 05, 2011 8:48 am
Hi.. I have the same problem, the CPU goes to 100% when active Motion2
Fails to soften the movement because, the FPS (frames per second) are unstable due to the very high 100% CPU usage
¿Is this nomal or I have a configuration problem?
My system setup is:
CPU: Intel C2D E2160@3Ghz, 2GB Ram
GTS250 Nvidia Graphic Card
Last Nvidia 266.58 drivers
Windows 7 64 bit
¿Any solution?
Thanks.
Anonymoose
PC Specification: GTX260 / Q6600 / W7 SP1
Sun Mar 06, 2011 5:10 am
post full system specs in both configs...
I doubt it's the 8200 (2.33Ghz 4MB cache)
monkeyman
PC Specification: Pretty good one.
Contact: ICQ Website
Fri Apr 01, 2011 9:36 pm
I'll add my 2 cents to this topic. Yes, CPU usage with Motion2 enabled is NOT normal. For me it goes from 50 to 80%. That's just crazy.
vivan
Sat Apr 02, 2011 6:46 pm
Frame interpolation is task that required a lot of analysis. E.g. it's possible to achieve better quality - by the cost of CPU (e.g. 3+ Ghz 4 or 6 core processor).
So yes, it's not normal. It's much less that could be.
PS Vita, Nokia N8
monkeyman
Sat Apr 02, 2011 7:34 pm
vivan wrote:Frame interpolation is task that required a lot of analysis. E.g. it's possible to achieve better quality - by the cost of CPU (e.g. 3+ Ghz 4 or 6 core processor). So yes, it's not normal. It's much less that could be.
Still not an excuse. Probably there's another algorithm which allows lower CPU usage with the same output quality. And I wish developers the best in finding it.
Right now Motion2 is well... not very good comparing to Philips' Natural Motion, but pretty much passable. But CPU usage is awful. Had to turn it off.
Nielo TM
Sun Apr 03, 2011 12:05 pm
Frame Interpolation (Motion2) requires a powerful CPU (especially when processing 720p or 1080p videos). Lowering CPU usage will result in poor performance. Think of it like running vector based graphics on a CPU.
It is better to move Frame Interpolation (Motion2) to the GPU, but we don't know when that will occur.
metal005
PC Specification: AMD1090T, HD4870, WinXP 32bit
Mon Apr 04, 2011 3:56 am
running 1.60 and 1.70 (with all the niceties on) on the relatively powerful quad-core AMD945@3.6G with the humble on-board GF8100 caused GPU over-heat
it seems that the software has been quite demanding on the GPU already
monkeyman
Mon Apr 04, 2011 9:02 pm
Nielo TM wrote:Frame Interpolation (Motion2) requires a powerful CPU (especially when processing 720p or 1080p videos). Lowering CPU usage will result in poor performance. Think of it like running vector based graphics on a CPU.
So, I guess, 3 GHz Core 2 Duo processor considers to be a "not powerful CPU" nowadays.
