ShavedApe
Not exporting
Tue Apr 03, 2012 10:29 am
I am a paid customer and at first action was working fine but now for whatever reason it has decided to no longer export my movies. I see the fic I click export it runs through the process of exporting but the file never appears.
Any help or advice on this would be helpful at this point as the program isnt much use to me as it is.
ShavedApe
Re: Not exporting
Wed Apr 04, 2012 2:49 pm
All fixed thank you to support for the prompt email and your time.
