antoineber18
PC Specification: Win 7 64
Problem when recording BF3
Sun Apr 08, 2012 2:52 pm
I've got a problem whit that fantastic program when I try my plays on Battlefield 3. The recording seems to be blocked, it seems to be impossible to launch it. The HUD doesn't appear, and I can't record.
Do you know why ?
Thanks in advance, and sorry for my bad english
Re: Problem when recording BF3
Sun Apr 08, 2012 4:31 pm
Does the benchmarking HUD appear (blue one)? If yes, try to change your default hot key for recording (F9) for another one, because the default one may be taken in game for another action.
Tell me if this worked for your, if not we will find another way to solve your issue.
antoineber18
Sun Apr 08, 2012 4:51 pm
No, the problem is that even the HUD doesn't appear, and that's why I don't think the problem comes from the hotkey, as I tried with three different keys.
antoineber18
Mon Apr 09, 2012 6:46 am
Problem solved ! It came from shaders that I added myself in the game, now ot functions perfectly ! Thanks for your answer
