MrDerp
PC Specification: Vista
TrueHD 7.1 not working?
Mon Apr 09, 2012 4:53 pm
I'm trying to watch a movie with TrueHD audio but I'm not getting any sound. Most movies have DTS-HD MA and I've never had a problem with Splash. I've tried going to the settings and picking the 7.1 option but that doesn't work. I switched to the 5.1 and stereo surround options as well but it didn't work. It plays fine in VLC but Splash has slightly better image quality/color. From what I've read some say that Splash PRO doesn't support TrueHD, other says that it works for them.
pirotrav
PC Specification: i7 2600k, radeon hd6870, 8gb RAM, win7
Re: TrueHD 7.1 not working?
Fri Apr 13, 2012 11:53 pm
Splash does support 7.1 truehd but ONLY using bitstreaming options. That means hdmi. Not sure if s/pdif works for this. Otherwise, it cannot play. DTS-MA probably works for you because it has a -core, which means that it is standard dts packaged inside of the dts-ma file.
