Splash PRO 1.6.0
Sat Mar 12, 2011 12:45 pm
We are happy to introduce the latest Splash PRO 1.6.0 version.
Changelog:
* Motion² Ultra 1080p option added for the ultimate video quality. This feature is designed for processors with 4 (or more) cores. (available in Settings/Video)
* Motion² quality improvements
* NVIDIA® Optimus detection improvements
* Improved 25p/50i video playback
* Multicore support improvements
* WMV playback improvements
Florin64x
Contact: Yahoo Messenger
Re: Splash PRO 1.6.0
Sat Mar 12, 2011 12:51 pm
Can * Motion² Ultra 1080p option added for the ultimate video quality. This feature is designed for processors with 4 (or more) cores. (available in Settings/Video) be enabled on 3 cores processors too , cause i have 3 cores processor phenom II and i cant enable this feature.
vivan
Sat Mar 12, 2011 1:01 pm
When russian language choosen - "?" symbol instead of "²" is shown...
PS Vita, Nokia N8
Voorhees
PC Specification: i7 920, gtx 470 sli, win7
Sat Mar 12, 2011 2:37 pm
great improvements on motion 2. after following this project for a while im going to buy the player and give my support.
keep up the good work.
looking forward to more improvements. :)
nagoli
PC Specification: Phenom2 965, 4Gb DDR2, HD5830, Win7 x64
Sat Mar 12, 2011 6:14 pm
Hi Team,
I bought this app at around 1.2 and I have to honest at 1.4 is was starting to get a bit worried that it's not going to deliver what I was expecting but the last two versions gave a huge boost in development!!!!
Keep up the good work and I'll keep recommending it to my friends.
Nielo TM
Sun Mar 13, 2011 1:25 am
Excellent and thanks for the 25p support. Finally I have one more reason to upgrade to i7 ^_^
PS: When can we expect Motion2 to be offloaded from the CPU to the GPU?
tuvi123
Sun Mar 13, 2011 11:11 am
Some suggestions:
SUBTITLES:
1) BOLD subtitles.
2) IDX/SUB format support, it's MUST-have - a lot of subtitles come in IDX+SUB format and Splash simply can't view them.(they take advantage of all options of Vsfilter/Directvobsub by Gabest)
3) ADD the option to change subtitle size by numbers (and not only by the pre-defined sizes).
4) ADD the option to prefer external subtitles over internal (like if MKV has eng internal subtitle and external fr srt subtitile - it will load the external and not the internal if the option is checked in the settings)
VIDEO:
1) ADD FLV support (if it will not possible dut to license problems then please add option to use external decoder for FLV to be used withe Splash player).
GUI:
1) ADD an option to Associate file types to Splash thorough the GUI settings.
AUDIO:
1) When using an MP3 with Splash the big screen with the logo is loaded, you shuld make it that when using splash to play music files it will load a small playing bar without the logo.
2) ADD playlist support for music.
thank you.
crl2007
Sun Mar 13, 2011 12:40 pm
tuvi123 wrote:Some suggestions:
SUBTITLES:
AUDIO:
thank you.
4) Splash already chooses an external srt if present and disables the embedded ones by default.
As for audio, this is a movie player, not a music player.
icsterm
Sun Mar 13, 2011 2:22 pm
Why isn't motion 1080p enabled for Core i5 mobile CPU's that have 4 HT cores? I think a 3 GHz clocked i5 should be fast enough. The tick option should be freely available for users to experiment.
Some dual core CPU's can keep frequencies higher than any Quad. Will it lag so bad?
Also, why skip versions so fast? There are features like in-menu file associations and some more 'critical' stuff missing,.
Nielo TM
Sun Mar 13, 2011 2:37 pm
Florin64x wrote:Can * Motion² Ultra 1080p option added for the ultimate video quality. This feature is designed for processors with 4 (or more) cores. (available in Settings/Video) be enabled on 3 cores processors too , cause i have 3 cores processor phenom II and i cant enable this feature.
It can't be enabled on Tri-Core systems
