Denonic
PC Specification: Core i7 920, GTX480 + Auzentech HT, Win7
Suggestions for next update.
Sun Mar 13, 2011 11:07 am
Awesome job with 1.6.0
Motion 2 Ultra does a much better job at judder reduction for HD sources than any other software solution I've seen so far and whilst its still not perfect it is a huge improvement over the previous non Ultra rendition.
One thing I believe needs addressing though is the ability to have the audio output mode set to HDMI Bitstream whilst allowing 7.1 lpcm or multichannel FLAC and AAC track output to be sent to the receiver. Currently it will only output 2 channels. Have tested changing the output mode to 7.1 channel and this plays them back fine. However it would be nice not to need to change this in the settings each time a non Dolby/DTS multi channeled track needs to be played.
The soundcard I am using is the HDMI Out from a Nvidia Geforce GT 430 using driver version 266.58 but have also tested this with the same results using an Auzentech X-fi Hometheater HD
Also another suggestion would be automated presets for Picture2 that can be set to change automatically depending on resolution and frame rate of the video being played. With those two things in place, I would be rid of my need for other media players all together. :D
Re: Suggestions for next update.
Sun Apr 10, 2011 10:37 pm
Thank you very much for your suggestions.
We pan to add automatic presets in the future versions but we do not know yet when this will be avialable.
About the audio I understand that when you select bistreaming you want all supported by receiver formats to be bitstreamed
and those not supported to be outputed to stereo/5.1 or 7.1 ouput?
Denonic
Mon Jun 20, 2011 12:48 pm
Ghost wrote: and those not supported to be outputed to stereo/5.1 or 7.1 ouput?
Yes. Bitstream works flawless but anything not requiring receiver decoding should output with its native speaker channels in tact. Currently it is outputting only as stereo regardless of whether the video file has a multichannel audio encode.
