azm
PC Specification: Acer aspir revo 3600, nvidia ion, win 7
How to set up MCE compliant remote control
Sun Mar 13, 2011 7:58 pm
I've been using Splash pro quite some time now and I absolutely prefer it over any other player. However, I'm not able to set up an MCE remote control to use its control (play, FF, Back, pause, stop etc). I tried setting up using Even Ghost but the latest version of Event Ghost has plugin only for Splash Lite not Splash pro.
Does Splash pro has any built-in remote control support? If it does, how do I set it up? How do other people setup remote control for their setup? Any advice/suggestion will be greatly appreciated. Thanks!
Re: How to set up MCE compliant remote control
Sun Apr 10, 2011 10:40 pm
HI, SPlash supports MCE remote controls, we tested it with several models
and it works out of the box just after installing rcu drivers.
Whatis your remote control model? If possible please provide a link to website with specification.
azm
Mon Apr 25, 2011 1:35 pm
Hi Ghost, this is the one I have
Sun May 08, 2011 9:54 pm
Thank you, will try to investigate a problem.
