paynkyller
PC Specification: laptop model dell n5010 inspirion
about update
Sun Mar 13, 2011 9:47 pm
mi laptop dont open mkv file after update to splash pro 1.6 whi?
parameter incorect,,,,,,
can you send me the anser to mi email plase?
thank you. :D
Re: about update
Sun Apr 10, 2011 10:40 pm
This seems to be a problem with Windows registry.
Try one of the following:
1) Automatic removal with a script.
- Download a script from
- Unzip it and run.
2) Manual removal.
- run regedit
- open HKEY_CLASSES_ROOT\Applications\SplashPro.exe\shell\open\command
- there should be only "(Default)"
- delete multistring (Type: REG_MULTI_SZ) "command" value if it exists.
