ARMAbest
PC Specification: Windows 7 Ultimate 32bit
MKV Splash Video Bug
Sat Mar 19, 2011 11:25 am
Hi i have a problem on a specific MKV i am trying to watch, the problem is that i got glitches(green glitches instead of the movie) on the video though audio is fine, i opened the same file with other programs , such as VLC , Media Player and the video is just fine , can you help me please? I really like splash and dont wanna watch the movie using other players , thanks.
PC Specs: Inter Core 2 Quad @ 2.4 | ASUS EAH 5750 Series | Windows 7 32 Ultimate
Helios
Re: MKV Splash Video Bug
Tue Mar 22, 2011 8:22 am
Hi ARMAbest,
try disabling GPU acceleration and test the file. If helped, try upgrading/downgrading the GPU drivers and test with GPU enabled again.
ARMAbest
Tue Mar 22, 2011 8:00 pm
Thanks man , that seems to work , anyway i downloaded the latest GPU drivers but it's not working :cry: , do you have any other suggestions?By the way you have a nice username , i am from Greece so...
metal005
PC Specification: AMD1090T, HD4870, WinXP 32bit
Mon Apr 04, 2011 4:43 am
Helios wrote:Hi ARMAbest,
in that case why not just state the standard ATI and Nvidia driver version sanctioned by Mirillis?
after all, only ATI and Nvidia
