Nielo TM
Re: Splash 1.2
Tue Sep 07, 2010 12:59 am
Joco1114 wrote:First experiences:
- it can play all MKV with audio
- sloooooow... With Picture2 I cant play MKVs with bitrate over 8-10 Mbps. I get cartoon-like movie: 2-3 seconds between frames. In these times the sound is gone too with green flashes. If I turn off Picture2, everything is OK.
Sorry, back to 1.1.
Have you tried disabling hardware acceleration?
Joco1114
Re: Splash 1.2
Tue Sep 07, 2010 4:44 am
Nielo TM wrote:Have you tried disabling hardware acceleration?
Yes, of course, everything went fine, but the quality was very week. :(
Home Theater:
Synology NAS 1010+ | 9TB HDD
Joco1114
Re: Splash 1.2
Tue Sep 07, 2010 4:57 am
I use this MKV for testing:
"Home 2009 Blu-ray 1080p AVC DTS-HD 5.1.mkv"
It's a 21GB monster with very high average bitrate (16-20 Mbps). With Splash 1.1 I didnt get any sound, but the picture was perfect with Picture2 (Motion2 = max).
With Splash 1.2 I get the sound but (as I wrote before) the movie went to slideshow. I thought the program needs time to caching. Waited for minutes, but the experiences are the same. Green flashings, audio and video unsynchronized, and nice slideshow. Splash using my 2 CPU cores above 80%.
P.S.: I've tried to play a tiny 3GB Full HD movie with low bitrate. (Ice Age 1) Same experiences. :|
Of course, other programs with GPU acceleration can play smoothly both video.
Joc
Home Theater:
Mastiffman
PC Specification: Which one? :o)
Re: Splash 1.2
Tue Sep 07, 2010 10:02 pm
I'm expereincing DTS HD lossless cutting out over SPDIF still as with 1.1. I thought that I read that this was an issues that will be adressed. All that I have to do is switch the audio source to the 2nd track which is DTS (not DTS HD lossless) and it's fine. not really a big deal I guess but it would be nice to not have to switch the sound to the second audio track for each MKV movies that I saved with HD lossless.
I'm also expereincing the choppyness in picture with motion2 enabled, no matter the setting. But if i turn it off the 1080p MKV play fine.
I also noticed very minute micro-stutter a few times during MKV playback. but it;s still Way better than all of the other progams that I tried...
pengbummzack
PC Specification: Athlon XP 3800+, Ati HD 2600pro AGP, XP
Re: Splash 1.2
Wed Sep 08, 2010 2:07 pm
with this version I got two new issues:
- playback on extended desktop with gpu enabled is not smooth anymore (looks a bit like 15fps)
- playback with gpu disabled looks like 2-3 fps
system is xp sp3
card is agp 2600hd pro
didn't change anything since ver. 1.1 (which worked)
Rodz
PC Specification: Win7 x64 Core2Duo 2Ghz, 4GB, NVidia9400
Re: Splash 1.2
Fri Sep 10, 2010 5:32 pm
Mastiffman wrote: I'm also expereincing the choppyness in picture with motion2 enabled, no matter the setting. But if i turn it off the 1080p MKV play fine.
Yep, same here. The only way I could play my MKVs without stuttering was by disabling Motion2 (Detail and Light boost are on and don't seem to interfere with the stutter). But I really enjoyed the Motion2 effect. It's a shame that it seems to be broken in this new version.
pengbummzack
Re: Splash 1.2
Mon Sep 13, 2010 2:56 pm
pengbummzack wrote:with this version I got two new issues:
system is xp sp3
problem still exists with ver. 1.2.1
