Durandal799
PC Specification: Intel i5 CPU, 8 GB RAM, 64-bit sys, Win7
Re: AMD MP4 60FPS becomes 50FPS in the output file
Mon Jul 27, 2015 3:06 pm
Do I need an update? I'm running 1.24.1.0. What settings do I change?
MrTra1tor
Mon Jul 27, 2015 7:56 pm
Durandal799 wrote:Do I need an update? I'm running 1.24.1.0. What settings do I change?
Just make sure that the "check for update" box is ticked, restart the program and pray to GabeN or Mirillis that it will detect a new version.
I can't confirm it, but another user mentioned that it will only display the tiny notification once per restart, so if you see it, but you fail to click it in time, you're gonna have to restart your PC.
Yes, it's a bug.
If you're not patient/lucky enough, here is the link to the version history of Action!: https://mirillis.com/en/products/action_history.html
Just download the latest (1.25.5 as of now) and keep your old version adn Action! should detect it as an update and keep all your settings.
