Rainbow
PC Specification: Graphics card
Re: splash 2.7 crash windows 11
Thu Feb 19, 2026 12:37 pm
Go to the installation folder and remove the file "libmfxsw32.dll"
andor360
PC Specification: 5300g
Wed Mar 04, 2026 1:41 pm
I found a workaround thats working perfectly so far. Go to the installation folder and remove the file "libmfxsw32.dll" (i recommend backing it up first)
Source: @Morgulen - Nvidia
neowatio
PC Specification: i7 11700 rtx 4070 windows 11 version H2
Wed Mar 18, 2026 7:42 pm
Buenas, a fecha de hoy solo funcinan los controladores de ndivia en la version 581,80 de noviembre.
krsolecheta
PC Specification: i9 12900f, 64gb ram, rtx 4060ti,win11
Tue Apr 07, 2026 6:38 am
si hace semanas que lo reportamos y no mueven ni un dedo para corregir
revper
PC Specification: i9 12900K, RTX 4070S,Windows 11Pro 25H2
Wed Apr 08, 2026 5:24 am
I have identified the culprit: libmfxsw32.dll. This library serves as the engine for the "Intel Media SDK," which Splash utilizes for Intel-based software and hardware video acceleration. On Windows 11 25H2, this outdated engine causes a critical conflict with the new system kernel
and current video drivers.
To apply these changes to future installations—or on other systems running Windows 11 25H2—here is the simplified procedure:
Definitive Solution for Mirillis Splash on Windows 11 25H2
1. Install Splash as you normally would.
2. Delete or rename the file `libmfxsw32.dll` located in the installation folder (by default: `C:\Program Files (x86)\Mirillis\Splash`). This forces Splash to utilize more modern video engines that are compatible with Windows 11 (such as DXVA).
krsolecheta
Thu Apr 09, 2026 8:05 am
work perfect, thanks so much
clewlily
PC Specification: Core Ultra 5/7/9
Wed May 20, 2026 6:36 am
I created a fresh account here. MSI B450 GPU, GeForce driver 591.74, Win11 x64 25H2 OS build 26200.7623 (January 5, 2026)
neowatio
Fri Jun 05, 2026 9:43 pm
Hola, solo me funciona co el controlador 581.80.La ultima solucion de cambiar el archivo o eliminarlo no me funciona.
Soy el unico o le pasa a mas gente......GRACIAS
neowatio
Sat Jun 13, 2026 4:33 pm
Hola, 13 de junio solo funciona con el controlador de ndivia 581.80 la eliminacion del archivo que postean mas arriva no funciona.
neowatio
Thu Jul 09, 2026 2:32 pm
Hola hoy 9 de julio ha dejado de funcionar Splash 2.7 incluso con el controlador de ndivia 581.80.Una pena que no se soluciones el problema.El mejor reproductor con diferencia en calidad de video lo estan dejando de lado.
Return to “Splash 2.0”
