Joco1114
Re: Splash PRO 1.2.1
Thu Sep 16, 2010 8:06 am
Back to ON:
@Marsianin and BDX: I didnt mind about the close button, but I think is not a big deal to place all menu-bar to the right upper corner instead of left upper. Maybe it will be more useful, though I never used it. ESC is good for me -> I have dedicated buttons (Space, Enter, ESC) on my remote.
Home Theater:
Synology NAS 1010+ | 9TB HDD
Marsianin
PC Specification: Core i7 965, 12Gb, 2xGTX280, Win7 x64
Thu Sep 16, 2010 8:04 pm
Joco1114 wrote:MPC != MPC-HC
Ok, sorry.
Anyway it uses third-party codecs. You don't need to install them because they installed automatically and loading all these codecs takes much more time than SplashPRO even on my stripped RAID array.
But current release of SplashPRO is very very buggy.
Re: Splash PRO 1.2.1 & 1.2.2
Fri Sep 17, 2010 4:45 pm
Splash PRO 1.2.2 is released with small improvements.
What's new in Splash PRO 1.2.2:
* MKV and AVI playback improvements
* Stability improvements on Windows XP
* Multiple MP2 audio tracks support in TS/VOB files fixed
* Automatically load subtitles from file improvements
* Translations improvements
* Ukrainian translation added
crl2007
Fri Sep 17, 2010 5:15 pm
Great, and now the subtitle loading bug is fixed.
LE: Now another ugly bug has shown his face. When you add files to the playlist and close the playlist, the player crashes. This behavior occurs when you have a movie playing and you want to add another one to the playlist. If you don't have a movie playing or pause the current one, than it does not crash.
icsterm
Contact: Yahoo Messenger
Fri Sep 17, 2010 7:53 pm
Download link broken.
Fri Sep 17, 2010 9:57 pm
crl2007 wrote:Great, and now the subtitle loading bug is fixed.
Thanks for reporting, will try to repeat this later on our PCs.
icsterm wrote:Download link broken.
There was a short 10-15min problem with servers, probably you have been so unlucky to land on the downloadpage at this time. Sorry for the inconvienience. It works now.
resinate
PC Specification: Win7 Ult
Fri Sep 17, 2010 11:12 pm
since 1.2 came out any mkv or avi files i have with +10 motion plus freezes videos every 5-10 mins.
does anyone have the link for 1.1 pro so i can use that until this is fixed cuz i didnt pay no 20$ for what the free player has.
Joco1114
Sat Sep 18, 2010 5:57 am
resinate wrote:since 1.2 came out any mkv or avi files i have with +10 motion plus freezes videos every 5-10 mins.
Same here. I turned off the GPU acceleration and (with lower quality ofc.) I can play all videos smoothly. :shock:
Home Theater:
micha82
PC Specification: WIN XP SP3 / WIN 7
Sat Sep 18, 2010 7:07 am
So, for me i can not confirm that subtitles load automatically :(
I tried several mkv´s with forced subtitles, they just do not load. I still have to turn them on by hand.
Tried it in XP and 7.
Could you kindly take another look on this problem?
If you need further information, please let me know!
Thanks!
Ark
PC Specification: Core2Duo , ATI 4670 , Windows 7 64
Sat Sep 18, 2010 9:15 pm
Same here , also subtitle flash very often when enable GPU acceleration
