for Mirillis team (If you did not notice my previous post)
Please add an option to change the subtitle font (font name, style, size, colour, script etc..).
also add a hotkeys support to change the subtitle size & move it up/down.
thank you.
Splash PRO Export.nunatak wrote:Very good, which product you are planning to release next?
Try pressing "0" (zero) on keyboard to reset Splash windows/panels positions.yilmaz196 wrote:I cant open playback options section since i updated to new version. What is wrong. I press the button but nothing happens.
Soon some improvements for subtitles will be introduced. More options will be added gradually.tuvi123 wrote:Please add an option to change the subtitle font (font name, style, size, colour, script etc..). ...
Will check this out...Nielo TM wrote:...Motion2 need a little color tweak. When Motion2 is enabled, the color becomes slightly shifted towards to green. ...
Can you provide a screenshot? Does problem repeat with all 720p files? Whats your settings (h/w acceleration, motion2 etc.)? What is video codec detected?BDLAB wrote:720p playback is distorted, 1080i/p works. Any ideas ?
Thank for all comments and suggestions.Marsianin wrote:...
A lot of lags in HD mkv movies when just playing, don't have idea why but SplashPRO 1.1 plays fine these files.
Very buggy SmartSeek feature with lags (worked fine in v.1.1.0)
Subtitles for inscriptions in the movies or foreign languages never shows (all other players displays them when needed)
1) Splash requires 59/60Hz display at the moment for smooth video playback.micha82 wrote:...
1) If i switch the graphid card of my HTPC (Nvidia ION) to 24hz, the video is stuttering in Splash. Switch i back to 60hz, everything is fine. Did anyone of you notice that as well? Just to be sure if it is a Splash or driver problem.
2) If playing a video file (e.g. MKV) and a subtitle track (normally forced subtitles for scenes spoken in foreign language, etc) has the "standard flag", Splash should recognize this like other players and turn this subtitle automatically on.
3) Option to start playback from the beginning in Fullscreen-mode
Could you please describe the problem more detailed, cause we cannot repeat this on our PCs.crl2007 wrote:...
LE: Now another ugly bug has shown his face. When you add files to the playlist and close the playlist, the player crashes. This behavior occurs when you have a movie playing and you want to add another one to the playlist. If you don't have a movie playing or pause the current one, than it does not crash.
resinate wrote:...since 1.2 came out any mkv or avi files i have with +10 motion plus freezes videos every 5-10 mins.
does anyone have the link for 1.1 pro ...
Please try disabling PGS support and please keep us informed if it helps or not.Joco1114 wrote:Same here....
micha82 wrote:So, for me i can not confirm that subtitles load automatically
I tried several mkv´s with forced subtitles, they just do not load. I still have to turn them on by hand.
Tried it in XP and 7.
Please try disabling PGS support (described somwhere before in this post).Ark wrote: Same here , also subtitle flash very often when enable GPU acceleration
What video codec is in this avi files? If it is divx, xvid please provide info what Divx/Xvid codec do you have installed.crl2007 wrote:... And AVI playback is still crappy. On some avi files, after I close the player, the player does not shut itself down.
I have tried "PGS=0" version, but I think it is worst then before. What is PGS means?Ghost wrote:Please try disabling PGS support and please keep us informed if it helps or not.Joco1114 wrote:Same here....
To disable PGS please open Splash config file (usually: C:\Users\USERNAME\AppData\Local\Mirillis\config2.ini) and add a line "PGS=0" at the very bottom. Then test movies without enabling subtitles.
