New version is now out: https://mirillis.com/en/downloads/downloads_action.html
Changelog: https://mirillis.com/en/products/action_history.html
jacksepticeye wrote:Hi there, Yes I am the real oneMrTra1tor wrote:
Slightly off-topic here, but are you the real JackSpeticEye?
And back to on-topic, contact the support team and they should supply you on a downgraded version of Action!. Ask for version 1.20.2 (the previous one), and 60 FPS videos should be just fine.
Also, how do you get 1080p on regular MP4? I thought that only the AMD MP4 had that feature (besides AVI).It's been causing issues with videos for me lately and ruining my workflow
That's a good idea, thanks for the tip. I'll try to get in touch with them about it.
If I choose the Nvidia Encoded option it lets me do 60fps MP4, the regular MP4 didn't. I probably should have clarified in my original post WHICH MP4 it was
Mic crackling sounds still happening for me in Dragon Age: Inquisition :Sradi wrote:New version is now out: https://mirillis.com/en/downloads/downloads_action.html
Yeah, I got the same issue, except I get 40FPS instead... The framerate of the output video seems to be off by quite a bit, atleast on AMD MP4.vision wrote:I'm so happy that I'll finally be able to record my gameplays, one thing when I record the video is recorded at 50fps not 60fps
I think the problem is that sometimes you can have a fps drop (because the game is bad optimized or whatever), and now when that happens, Action put down your video frame rate.vision wrote:lol my computer is enought to record 1080p at 60fps i'm sorry but is your program that have some bugs, because i dont have any problems recording with other programs at 60fps but its okay! Now the program is better as before and thanks for the hard work.
Is there any way I can disable it?radi wrote:This is what variable frame rate is. If your computer cannot handle to maximum settings you have set it will change automatically the frame rate to keep the video without stuttering and any additionally interruptions such as audio desynch.
