Despi
PC Specification: intelcore2 2g, gf gtx 260m, win7, 4g ram
Problem With the final file [RESOLVED]
Wed Sep 05, 2012 7:09 pm
The captures are good, no problem in the program.
The source file capture (avi) run in windows media player and work well.
Same for the exported file (mp4).
But i can't use them for make à movie in vegas pro or adobe first élément.
source file :
vegas pro = lag
adobe = lage
exported file =
vegas pro = not picture, just sound
adobe = crash program when i open it.
can u help me plz ?
(sry for my english, is bad)
Re: Problem With the final file
Thu Sep 06, 2012 10:34 am
Try this:
1) Download (7MB) and install Yamb - http://www.videohelp.com/tools/YAMB
This is an easy-to-use program for fixing MP4 files so they can be accepted by AE 5 but it should also work for Sony Vegas
2) Start the program, click ADD and selected your exported MP4 Action! file.
3) Click "Mux" in right bottom corner.
4) New created MP4 files should work correctly now with your Sony Vegas.
The "muxing" process does not affect the video quality and usually takes few minutes.
Despi
Thu Sep 06, 2012 6:44 pm
did it. mp4 work well. thanks a lot.
work with all file or just .mp4 ?
but what about the source file (.avi)
why lag ? because i would like work with the source file for videomaking, not a file allready convert and reduce.
Thanks
Thu Sep 06, 2012 9:33 pm
Despi wrote:did it. mp4 work well. thanks a lot.
Thanks
Is it lagging only in preview inside the editing software?
Despi
Mon Sep 10, 2012 7:52 am
yes, when i launch it for preview
just i clik on "play" in vegas for run it, and lag begin
Mon Sep 10, 2012 10:51 am
Despi wrote:yes, when i launch it for preview
If it's only happening in Sony Vegas preview then don't worry. After you render your video it should be fine and no longer lag.
Despi
Re: Problem With the final file [RESOLVED]
Sun Sep 16, 2012 8:27 am
Allright, thx for your help, i close the topic.
