indigobv
PC Specification: i9 9900K, RTX 3090, 32GB DDR4, Win11 Pro
Request: Excluded apps
Mon Oct 01, 2012 9:08 am
Hi! Could you add in a future version a place where we can select which apps not to use Mirillis Action? I think it would be better than bothering you every time the HUD shows up in an app where shouldn't. I know you can disable it or turn it off with F6, but it's annoying after a while. And sometimes even after pressing F6, because the interface doesn't refresh, I need to drag the window out of the screen and bring it back in order to clear up the HUD.
As an example I have Logitech Gaming Software where the HUD is covering minimise and close buttons.
If there isn't going to be an exclusion list, then could you remove the hud from this app?
Thank you.
dimanish
PC Specification: i5-2500k, gtx680, 16GB ram, win 7 sp 1
Re: Request: Excluded apps
Wed Oct 03, 2012 6:51 pm
+1, join this request
It will be great if configurable exlcluded list of apps will be added in future release.
Even most of video players use directx as output and I need to hide Action! overlay with hotkey each time I open some video.
Thu Oct 04, 2012 10:05 am
This feature will be added in 1.11.0.
Fri Oct 05, 2012 9:04 am
Exclude list is now available with latest Action! 1.11.0 version.
Tutorial - Adding processes / applications to Action! exclude list
http://mirillis.com/en/products/tutoria ... -list.html
