TripleTJon
PC Specification: Windows 7
Recording games that are do not have Direct X 10
Sun Oct 28, 2012 7:55 pm
Hello Action! people. So my question is if there is anyway to record games that do not have Direct X 10 or whatever is supported by Action! without having to switch them into windowed mode. So far for every game Ive had to put it into windowed mode which as I see it decreases the quality of the video in the end. when I do run the game in windowed mode I have to put it into 800x600 because 1024x768 goes off the bottom of my screen. If there is a fix for this or a future update that would be great. Thanks! Also what would the optimal settings be if I want to record then export then edit then export again? Thanks!!!
Re: Recording games that are do not have Direct X 10
Mon Oct 29, 2012 12:09 pm
Action! supports DirectX9 and higher. Lower DirectX version can be recorded via Region Desktop Mode when they are windowed. What's your regular screen resolution?
TripleTJon
Mon Nov 12, 2012 6:23 pm
My normal screen resolution is 1366x768. If I try and run a game in windowed mode with the height being 768 the game window runs right off the screen so I cant do active region that way. Its just a minor frustration thats all.
