pettergulbra
No picture, Sound in very high speed
Thu Jan 21, 2010 6:05 pm
Hi
When I trie to use this player there is no picture in the video, but there is sound, but the sound goes so fast that I can`t get what I`m listning to.
Is this a known problem?
My system? Se the signature.
Kindly
Petter
Core2 Duo T9300, 4GB ram, Mobile Intel 965 Express Chipset Family
vivan
Re: No picture, Sound in very high speed
Thu Jan 21, 2010 6:55 pm
I got the same problem on .mpg file with MPEG-1 video and MPEG-1 Layer 2 audio - it's probablly just unsupported.
What type of file are you trying to playback? (what info(I) splash lite gives on that video?)
PS Vita, Nokia N8
pettergulbra
Thu Jan 21, 2010 7:32 pm
I trie to play .mpg file, stream type .vob
But I trie an .mkv file also. last day it worked, but no picture or sound. But to day, it dosent play at all. The program just hangs.
Watchman
Thu Jan 21, 2010 8:29 pm
Hello Peter,
Thanks for the feedback. We are currently extending our MPEG-2 video decoder for MPEG-1 support so it should be available soon in Splash Lite. MPEG-1 Layer 2 audio is already supported.
The problem with MKVs you are having is not common but we will try to figure something out basing on your computer's configuration.
PS. What kind of OS are you running (XP/Vista/Win7)?
Best regards.
pettergulbra
Thu Jan 21, 2010 9:14 pm
I use Win7 x64, If there is anything else you need, just ask.
Have you built in an log function in the program?
Petter
Thu Jan 28, 2010 8:51 pm
pettergulbra wrote:I use Win7 x64, If there is anything else you need, just ask.
Petter
We do not use any log function in our software.
Does the problem with MKV file repeats for all mkvs?
You said that day before it worked but there was no picture and no sound?
What is your current graphics drivers version and dou you keep drivers up to date?
pettergulbra
Fri Jan 29, 2010 5:58 pm
Yes, I said i worked, because the progress bar was moving. But no picture or sound.
.mkv files does not work at all.
I just have 3 .mkv files, but I hope it support this, because an mkv is an mkv.. I don`t want to use one player for one type of mkv and one for some others.
Else this program looks great.
Petter
Thu Mar 25, 2010 10:20 pm
Please open info panel (press "i") and check what audio (full info including channels and Hz) and video types are detected by Splash.
If you have any mkv samples that do not work with Splash and if you could share with us, please contact us at support@mirillis.com.
